Sailfree
Last year I replaced my thro hull fittings with CR ones.
This year one of the new ones shows pitting similar to an anode. The other 9 are perfect. All are marked CR.
Sent a photo to ASAP and they have sent me replacement fitting, ball valve, rt angle bend and tail FOC as I would never be able to split the Locktited fittings.
Now struggling to cut thro thread to preserve corroded outside bit for ASAP to investigate cause. ( I would usually grind off the outside flange)
Sod's law it would have to be the fitting that's the lowest and hard against a bulkhead. Got some of thread sawn through using a multi tool but blades not long enough to get to bottom part of thread 1.5" ball valve size! Probably going to be. slow work with a part hack saw blade but today will try method 2 and will try to undo inside nut with wide adjustable but access almost impossible and even then not sure I will be able to poke fitting out as the cured PU40 will probably be strong enough to hold the fitting in place.
Fitting is isolated ( not bonded) so like ASAP really would like to understand the cause.
Open to ideas for removal! Are there longer multi tool blades available anywhere?
