As the water temp rises , Ellen...
BobE
15 Jan 2002
Hampshire (West)
seems to be going slower..Is there a tie in between speed 'n wter temp that I don't know about..
"Put the kettle on Hardy the enemy's in sight" ??
Cheers Bob E..
D
Deleted member 478
Not that I know of, but as you get closer to the equator, the wind gets lighter (doldrums) and the water gets warmer (can expect it to reach 30deg C).
BlueSkyNick
29 Apr 2003
Near a marina, sailing club and pub
Stingo You've just reminded me of something I keep meaning to ask you.
Did you notice the water going in the opposite direction down the wash basin drain when you crossed the Equator?
As you would have sailed at a fine angle, ie more E to W than N to S, presumably this phenomenom was apparent for quite a while.
D
Deleted member 478
It's true. Having been brought up in South Africa, I was quite confused to see it going the wrong way around when I moved to the UK.
D
Deleted member 478
Absolutely. Even the sun comes up on the wrong side in the Northern Hemisphere.
snowleopard
Oxford
perhaps she's having the same problem as me, wondering why the wind is going anticlockwise round a high and giving her headwinds when they should be from behind /forums/images/graemlins/wink.gif
Danny_Labrador
13 Oct 2004
Harrogate
That’s funny, last time I read about the, water /plug hole /hemisphere rotation phenomena in New Scientist it said it was total bollocks – but there you are my data bank stands corrected.
snowleopard
Oxford
back to the original point. i suspect her lack of progress has more to do with the force 2 headwind than any minute differences in viscosity or density of the water (which, incidentally would both tend to increase rather than reduce her speed!)
