Are there specialist pliers to remove this ring nut?
Skylark
4 Jun 2007
Home: North West, Boat: The Clyde
After a great deal of cursing, I managed to remove the tap ring nut shown in the picture using external circlip pliers. The pin diameter on the pliers is a good bit smaller than the holes in the nut, hence a lot of slippage causing burring of the nut.
This is the nut once removed.
Anyone know of a specialist tool to remove the nut with less swearing required? Ideally adjustable to suit various sizes of nut, not fixed pin distance.
Many thanks.
Many thanks.
549248
http://www.halfords.com/cycling/bike-maintenance/bike-tools/unior-adjustable-pin-spanner
Get a Watch-back Removal Tool from Ebay.You can fit two points that are a close fit in those indentations and then open them out to the correct distance so that they do not jump out of engagement. Cheap and effective.
Alternatively cut a short length of mild steel flat bar. File the edges to fit in the indentations and use it like a screwdriver; apply a small adjustable spanner to turn the flat bar and the nut. Even cheaper and just as effective although not as efficient.
