Ammonite
12v fridge runs fine off the domestic batteries when the engine is runnimg or the 240v charger is on BUT when just running off the batteries the compressor starts ok but the voltage under load drps away steadily until the fridge low voltage cutout is reached (10.7v according to the manual). Here's a few figures
Engine running:-
Nasa monitor reads 14.4v, receiving charge of 9.2 amps
Voltage across battery terminals while charging 13.92 (multi meter)
Voltage at all swithes in electrical panel 13.97v (multi meter)
Voltage at fridge when fridge off 13.95v (multi meter with 3 m cabl e run to fridge
Voltage at fridge when on and drawing 3 amps 12.8v (multi meter)
Switch off engine:-
Fridge starts drawing 3.5 amps according to Nasa monitor
Voltage at fridge drops to low voltage cut out in a few minutes depending on how long I have run the engine
Voltage at Nasa drops quickly initially and then stabilises at 12.8v dropping fairly slowly so its at at about 12.6v when the fridge stops
Both domestic batteries have a green battery ok indicator
Any guidance much appreciated!
Engine running:-
Switch off engine:-
