D
Deleted User YDKXO
I was reading the Beneteau Antares 12 mobo test in this month's Boats and Yachts for Sale and I was surprised to read that, for the IPS version of this boat, Beneteau flatten the aft end of the hull to give a shallower V. This is to provide more lift aft to compensate for the weight of the engines which are placed further aft in the IPS version. The standard shaftdrive version has a deeper V because the weight of the engines are further forward and, as a result, is considered by Dickies, the UK dealer, to be a better sea boat
Is it common that builders use a shallower V hull for IPS powered boats or is it just Beneteau with this particular hull? There have been comments in the press about IPS being less suitable for flybridge boats because the handling can be twitchy. So, does the panel think that flybridge boats are better having standard shaftdrive?
