simonfraser
can i just wire make A up to display B ?
transducer is 2000 vintage, display is new, VDO. will take 0184 input.
I'm assuming you mean 0183. Yes basically 0183 is standardised and you can mix brands. IF the transducer outputs 0183 (not all do) then you can wire it to the 0183 input of a display and it doesn't matter about mixing brands/makescan i just wire make A up to display B ?
gigm you would be correct if the transducer plugged into the plotter (or whatever) with a direct analogue cable. But the question here relates to a transducer unit that has a little computer inside it that makes it output nmea0183 sentences, rather than analogue data. Once you have got a 0183 sentence, you have an international standard and can usually mix up brands as much as you want.Many are made by Airmar...if you find the right area on their web page then there is a large table of compatability. Tbh..I am not sure if that is simply the plug fitting as different plotters use different sockets.
But a simple answer is no..transducers are generally plotter specific not generic.
EDIT..reading other replies I did assume you meant will any transducer simply plug into and work with anything....I had not considered you might want to chop the cable and make up a new plug ...��
