Anyone sailed a Walker bay 8?
FullCircle
19 Nov 2003
Would appreciate a bit of feedback,as I am considering a Walker Bay 8 with tubes and the sail kit..
I have a Walker Bay 8 with a "Performance sail kit" and without tubes.
I really enjoy sailing mine. The three of us (2 adults + 1 infant) can sail ashore for BBQ's without any probs. I can successfully sail the Walker Bay 'by the lee', although a moderate gust will spin the hull and throw you in! (I have a Laser 1 sailing background) Once capsized, you can right it by hand .... but it is VERY difficult to get back in w/o capsizing again. And finally, if you take the one peice oars sailing they are a PIA.
A friend of mine has a WB8 with tubes and has confirmed you can 'remount' with ease.
I also have a friend with a Seahopper. This has the advantage of being able to fit a rudder and outboard at the same time. Useful if you get cause out by the tide.
Thanks for that. Does that mean you cant mount the outboard offset if you have the sailing rig fitted?
We have an 8 with tubes and sail kit, you can’t have the O/B and rudder on at the same time. Do not get the standard sail kit as it is rubbish, I wish we had got the performance sail kit and might see if there is a good deal at Southampton.
The Walker Bay with tubes look like a brilliant idea- best of both worlds in some ways.
Is it possible to buy the tubes separately? Or could I press something else into service... like a *******ised inner tube etc... hmmmm.... winter project methinks.
All the bits are available seperatly even a nice bouyancy bag that laces securely around the drop keel case, Forgot to say but they also row really well but the oars do get in the way a bit when shipped and sailing. We lost one and replaced it with a pair of small Ali ones which are a lot less of a pain but also do not row as well.
They seem to have fairly low freeboard. Is that a problem when heeling or when trying to carry a lot of people and/or gear?
Not with the tubes on, the CE plate rating is a bit lower (even with the tubes) than the Quicksilver 270 airdeck of a similar size we had before though. As we carry it on Weavers and use it as a tender mainly I don't think I'd want one without tubes.
My walker bay has the old square rig which has the advantage of breaking down into shorter lengths for stowage. I lash three fenders each side for two up sailing. This is easy and quick. Lashing cord is permanent and goes round the securing bolts for the seats. Means I can have davits on a 28ft boat - heaven!
