FairweatherDave
Been studying Calder and Tony Brooks website trying to get to grips with basic boat electrics and first principles. I want to see if I have got this right. And apologies if I have got the terminology wrong!
I have already got the VHF radio installed. However rather than going back to the bus bar I would like to "common up", ie T off from the VHF circuit the AIS receiver, the Glomex splitter and the Garmin 72 handheld unit, (ie 3 things in parallel circuits). I want to check I have the right size cable and fuse that I can T off. So I need to total up my total current flow.
VHF is an XM DSC 25/1 watt radio. The manual spec does not give me any other obvious figure so at 12v that makes 2 amps?
The Garmin manual for the GPS says use a 2 amp fuse with a 12volt power source. So 2 amps. (probably OTT?)
The Glomex splitter uses 25mA at 5v so 0.125Watts
The Quark AIS again uses a micro USB from 12v to 5v step down thing, so 270mA (x5) = 1.35Watts
Combine those two Watt figures and round up to 1.5Watts and divide by 12 = 0.125 amps
So a total current of 4.125 amps on that original VHF circuit which would have a fuse sized for that (so 5 Amp fuse)
However the wire for each of the circuits I am adding on in parallel only has to be sized to the whatever I am putting in it, ie the Glomex splitter and the AIS can be pretty thin. The Glomex comes with an inline fuse too.
I think my confusion arises from the fact I am planning to add three circuits to an existing circuit and I'm not sure you simply add up the amps of each unit.
So anyone care to point out how many mistakes I have made
I'm sure I am taking this all a bit far as the bits and pieces I'm adding are all small but it seemed a good opportunity to learn some theory. Thanks for any pointers.
