C
catalac08
25hp (uprated by dealer to 30hp) 2 stroke 2005 vintage with about 450 hrs on the clock. Had to tilt the leg a few days ago and noticed that a small amount of oil was seeping from both the small holes holes close to the gearbox oil filler plug.
Had a look at workshop manual (clymer) which does not even show these holes on their diagrams and I am quite puzzled as to the function of these holes and where the oil is coming from. It has got to be gear oil but how & why.
Only possibility I can think of is that these holes are to drain the rear tube section that has the gear linkage in and is open at the top and perhaps I overfilled the gear oil, but that was at the start of last season and this oil is not milky as you might expect from oil sat in water or is does it only go milky when agitated.
I can obviously talk to the local tohatsu dealer but I would welcome any insight into what this is about and whether there is a problem before talking to him.
