Any tips on replacing Exhaust Elbow
jackho
22 Mar 2003
Replacing exhaust elbow on Volvo D1 30. Any tip on releasing the hose from the elbow and maybe idea on tools to help release .
I‘ve never had any particular difficulty releasing the hose from mine. Just undo the clamp and then give it a bit of a twist if it doesn’t pull straight off. I suppose you could jam in a flat screwdriver between hose and metal if it still needs some assistance.
If it is stuck on you might consider replacing the hose, these can suffer internal failure, if so just cut it off
