Any tips on how to drill straight ?
Leaving stainless steel aside for the moment. I am drilling holes in ply that are taking 3 inch studs and a fitting the other side. They need to be straight to in order not to foul the fitting body. Unfortunately, despite trying hard, my results are to say the least spotty ! plus I am running out of ply.
Any tips would be very much appreciated.
Many thanks in advance.
tcm
11 Jan 2002
Caribbean at the moment
If the py is loose (sounds like it) you need a proper stand and lever to bring the drill down vertically, can rent or buy one. Either way, dril a pilot hole (smaller dia) first, and if no stand get mate or wife to watch up a bit down a bit etc.
rich
7 Jun 2001
JERSEY
www.portofjersey.je
first use a bench drill stand, get a bit of hardwood drill your hole nice and staight,than use as a guide{or.cub} for your work.
rich
Peter_the_Grate
2 Jun 2001
Hampshire
I have a lightweight stand made by Black and Decker, which I use on such occaisions. It cost me £11 a few years ago; they're still relatively cheap compared with loads of wasted of marine ply. Be sure to get the correct one - B&D makes drills with two sizes of collar (by which the drill attaches to the stand). I bought the wrong one and ended up buying a second drill as well.
