Freebee
My outdrive will not shift into forward or reverse. With the outdrive raised and the forward gear selected I can turn the prop and get it to lock. But with the engine ticking over by manually pushing and pulling on the shift cable it will not go into either gear. with the engine on the prop seems to be turning at about 10 rpm in one direction regardless of which way I push/pull the shift cable. Am I right in thinking that the shift end of the cable can only be accessed from underneath the drive?
