Any idea what this pic is of?
DSWright1
New Member
29 Apr 2006
Bucks
I am baffled. Found this item on my boat but cannot work out what the hell it is for. Does anyone know?
Could be a roller reefing handle for the main boom.
These are used when the Mainsail is rolled around the boom to reef, as opposed to slab reefing of in mast.
It looks different to the ones I have seen but the suare on the end would certainly fit.
Martin
One sure fire way to find out what it's for is to throw it away.
Very soon after, you will realise that it was essential for some task.
Been there, done it.
We need some dimensions to have a more positive identification but if that rod is about 10 mm diameter with a square machined on the end I suspect it may be a replacement handle for a roller reefing gooseneck fitting.
On the otherhand if its about 25mm diameter or bigger i would suspect an emergency steering tiller.
PS just looked at your profile.Your boats not likely to have old fashioned roller reefing so I guess it could be a key for removing a plug from something .
Doesn't look like any lock key I've used. They usually have a square hole in which you put over the paddle winding gear.
Rick
Barton Reef handle are some people trying to say ?
Nope - as it hasn't got the ridge at end where "hand-bob" is fitted so that you can hold it and turn without the metal gouging your palm to bits ..... unless someone turned it up themselves ... without handle ?
I have a packet of metal tangs lieing in bottom of a locker .... couldn't fathom out those till it dawned on me - they are locking tangs for bottlescrews !! the ones that have the small tab in the body to lock it from turning !
IT is at least 3cm in diameter. It is pretty big and heavy, so I think I agree that it must be an emergency tiller.
Thanks very much for all the suggestions. But I have no idea how french canals got involved!!
It is the emergency tiller for your Beneteau - it looks the same as the one I have - I guess each arm is about 750mm long
