Any Hurth Gear box experts or ATF oil experts out there
Firefly625
18 Mar 2009
Home=Surrey / Boat=Hamble
My gearbox requires ATF fuild to dexron III spec - its a Hurth HSW 630 A1-2
Our Parts Dept have been having a sort out and have just asked if I could use 30lts of Shell Donax TA (ATF fluid) for my boat... (a lifetime supply!)
Just looked up Donax TA specs;
Typical Physical Characteristics
Donax TA (D-21631)
Kinematic Viscosity ISO 3104
at 40°C mm2/s 34.9
at 100°C mm2/s 7.2
Viscosity Index ISO 2909 141
Density at 15°C kg/m3 ISO 12185 871
Flash Point COC °C ISO 2592 180
Pour Point °C ISO 3016 -45
and Donax TX (dexron III spec);
Donax TX (G-34077)
at 40°C mm2/s 33.7
at 100°C mm2/s 7.3
Viscosity Index ISO 2909 185
Density at 15°C kg/m3 ISO 12185 845
Flash Point COC °C ISO 2592 185
Pour Point °C ISO 3016 -48
look fairly similar to the un-trained eye. Anyone see any issues if I put Donax TA in my gearbox instead of Donax TX...:confused:
..as my gearbox does still leak a bit I do often need to top it up so it is something I get through.
Spi D
25 Jul 2011
Denmark
Since ATf is quite inexpensive and that used additives are 'a factory secret', I'd stay with the recommended.
While you wait:
http://en.wikipedia.org/wiki/DEXRON
and
Shell Donax TX: Advanced synthetic automatic transmission fluid
Shell Donax TX is a superior quality, heavy-duty automatic transmission fluid, approved by major North American and European transmission manufacturers.
Based on Shell XHVI® synthetic base fluid and unique additive technology, Shell Donax TX allows for extended drain intervals even under the most severe operating conditions. It is suitable for applications in automotive automatic transmissions, automotive hydraulic systems, power steering systems and in some manual transmissions.
Performance features and benefits:
Shell XHVI® synthetic technology
Excellent shift feel for driver/passenger comfort and reduced wear and tear on components
Extremely low temperature fluidity for extreme winter and summer weather conditions
Shear stability to maintain fluid performance throughout the oil drain period
Wear protection from synthetic base oil and unique additive technology prolongs the life of sensitive transmission components
Maximum oil drain interval protection to maximize time on the road and reduce operating costs
High temperature oxidation stability
Shell Donax TA: High quality automatic transmission fluid
Shell Donax TA is a high quality transmission fluid that provides consistent, reliable, smooth and trouble free operation for most heavy-duty automatic transmissions.
It is suitable for many passenger car and heavy-duty automatic power transmissions, power steering and hydraulic fluid applications, and its unique additives and base oils provide excellent shear stability and long component life.
Friction modified for reliable, smooth and trouble free operation
High oxidation resistance minimizes oil degradation for consistent performance
Excellent shear stability from a special Viscosity Index improver ensures it stays ‘in grade’ for a longer period
Dependable anti - wear protection ensures longer component life for consistent gear and hydraulic pump applications
Red
11 Aug 2003
You are making a big mistake putting the wrong oil in your gear box. If Hurth recommend Dextron III use it, dont put Dextron II in or any multipurpose ATF fluid. When you get to the Alderney Race and your gearbox packs up you aint' going to be able to row your way out of danger and you will regret the pennies saves. Take up painting it is cheaper.....
DAKA
7 Jan 2005
Nomadic
Not sure if you are aware that your gearbox is a ZF
ZF recommend TA oil
ZF TE-ML 03d -04d- 09 -11A
Do any of the above codes relate to your manual ?
you quote your model of gear box as a 630 which is fairly old (hurth), the exact same gear box is now model 63 ( ZF dropped the 0).
Perhaps the new manual for the 63 does include the above ZF spec ???
Firefly625
18 Mar 2009
ZF recommend TA oil
Hi Daka, I knew it was a ZF/Hurth gearbox, I took the model number from the serial no plate on the top, which stated 630... but from memory the manual refers to a 63... boat was launch 2001, so gearbox may be anything from 1998-2000? just depends how long its been kicking around before finding a home in my Hardy. From memory don't you have the same gearbox? & if so what do you use?
Manual on the boat so I can't check on codes you referred to..
DAKA
7 Jan 2005
Nomadic
Mine is the 63 A exactly the same as yours but slightly different ratio 2.5 :1
My manual is 2004 and I use dexon III, I cant remember if another spec is also recommended or not.
An old 630 manual may well specify the above ZF approval ?
Im on my boat now and I think the manual is at home.
Assassin
23 Jun 2010
Donax TX is now called Spirax S4 ATF HDX and is backwards compatible, it is a synthetic lubricant instead of a mineral.
According to my literature it is suitable for your application.
Firefly625
18 Mar 2009
indeed I know TX is compatible, what I have sitting at work is a 30ltr barrel of Donax TA which we used to use in old Borg Warner units, its not synthetic and TBH I have already told the guys thats its not for me, I will use dexron III spec ATF as all manuals suggest. thanks all for your input. :)
