Memphis_Chung
Hi All,
So, the boat is back in the water and the weather this morning looked good for a quick motor up the harbour. Switched the donk on (it is a Volvo Penta 2002 18hp) with great excitement and anticipation. This is what happened:
1. throttled forward in neutral - fine
2. throttled back - fine
3. throttled forward in gear - fine
4. throttled back in gear - revs dropped to 500 and would not go any higher regardless of throttle. This was followed by the exhaust spewing out black smoke and a sludge of unburnt diesel.
5. Throttled forward - fine
6. Throttled back - same problem
The only way I could get reverse to rev normally was to throttle forward and then stick it in reverse without pausing at neutral.
The only other thing I noticed was that the engine was idling slightly fast from time to time (1200 instead of 850 ish).
I couldnt see anything wrong with the throttle cable/linkeages but then again, I am no expert.
Any ideas????
Thanks,
Tom
Any ideas????
Thanks,
Tom
