npf1
If a heating thermostat is capable of switching a max of 250VAC @ 3.5A what the max amps it could handle it 12VDC? The stat will work with DC. I need to be able to switch 1.5A @ 12VDC
If the stat isn't capable of of 1.5A @ 12V, should I use a relay or a transistor for the switching? If a transistor, any idea what type?
Hopefully there's enough info there to advise. Thanks in advance.
