Robin
I've just bought a BU-353 Globalsat USB GPS for my laptop, running Vista Business. I installed the software and a small program 'GPS Info' from the CD and followed the instructions to the letter.
OK, the GPS is working and has found a position. It is on COM21 port which is noted in the various nav software programs I have installed and baud rate is set at 4800 as instructed.
So, success so far:-
OpenCPN - working fine
Seaclear11 - working fine
Tsunamis - not working, cannot allocate the right port (21) as 1-10 only options shown
Neptune C-Map Planner - says port 21 'in use' cannot connect
GPS Info - port 21 entered but it finds no data. This prog is used to enable WAAS/EGNOS but it isn't allowing anything as it doesn't 'see' the GPS data.
I re-installed GPS Info but it still will not find the GPS data or any port even if the allocated one (21) is selected.
Any ideas????
Interesting that the two freebie progs, Seaclear11 and OpenCPN worked instantly whereas all the other expensive ones don't!
Any ideas????
