Norman_E
The autopilot on my boat is a Simrad Robertson AP11 with a J3000x controller/Junction box driving an electric pump-hydraulic ram combined unit. The latter was always a bit underpowered and examination following replacement of the upper rudder bearing has shown that it has become stiff to operate and is causing a lot of friction in the steering.
As the J3000x unit will only output a maximum 10 amp current to the drive unit replacement choices are limited unless I replace the entire system, which is a large expense. As far as I can see there are just two wires connecting the junction box to the drive motor, which is reversed by changing polarity. Is it a workable scheme to use the output from the autopilot controller/junction box via diodes to energise one of two relays (depending on direction of current flow) so that a higher powered ram can be used? What I don't know is whether the power output from the j3000x is a simple bi-directional on/off, or something that regulates the amount of current.
