newtosailing
- Joined
- 10 Feb 2005
- Messages
- 33
Hi all
Having read many of the entries on this forum over the last year or so - which provide great amusement and inspiration - I am just entering the planing stage for what will hopefully be a voyage from the UK around the med and then onto South Africa.
By way of background - I only really got into sailing 2/3 yrs ago and most of my experience to date has been as a crew member - largely in the solent area. Other than that I've crewed around Cherbourg area and did a passage from Penzance to Cork last yr for Cork Week. I did the RYA Day Skipper theory last yr and the practical early this yr. Thus far, I've only been the skipper for a couple of weekends and hence I recognise I need to get a lot more experience before I set off on the venture. Which I guess is why I am posting this. I am not a boat owner but a kind friend has allowed me us of his Hanse 301 to get more sailing experience whilst I consider what boat to buy and where to moor it etc etc. I am hoping to set off in 2yrs (by which time I am hoping that I can take as much time off as is required/desired). The plan is do this with the other half (provided that between now and then the heated arguements we've experience when sailing have diminished !).
I suppose my questions cover a myriad of subjects - so in no particular order;
a) if you were in the same situation - what would you do over the next 2 yrs to build experience (other than sailing around the solent!)
b) would you recommend doing the RYA Yacht master courses;
c) should the boat I buy be the one that I have in mind to do the voyage; if so - any advice on choice ? e.g size, necessities etc
d) how much sailing experience would you consider prudent/appropriate for my partner to have before the voyage;
e) I would welcome any comments from others that have sailed down to south africa - e.g which route is advisable, timing considerations, areas to avoid, etc
f) anything else that is worth considering that isn't covered by the above!
Sorry for the wide ranging nature of my questions. I look forward to any advice/comments. Thanks
