antifouling survey
jamie langstone
22 Dec 2013
Concern about DIY antifouling applications sparks survey
The British Coatings Federation (BCF) Marine Coatings Group says there is a concern that authorities may decide to restrict the application and use of antifouling (AF) paints to strictly professional applicators and organisations.
This is due to the concerns over the hazards related to these paints and would mean that the common current practice of boat-owners applying AF paints to their vessels (the ‘DIY’ market) would no longer be permitted.
A survey has been launched on ‘DIY Use of Antifouling Paints in the UK’, which will run until 30 November 2015. Find the survey at: https://www.surveymonkey.com/r/NPNB6NW
The main objectives for this survey are:
to raise awareness amongst the boat-owning community regarding this issue
to determine the current practice related to anti-fouling paint use by the DIY market
to determine the awareness of users to the hazards of AF paint, and emphasize the importance of using appropriate Personal Protective Equipment (PPE)
to provide an indication as to the impact on AF paint sales, boat maintenance costs and leisure boat ownership, if such a restriction becomes law.
The survey consists of four separate (similar) questionnaires, each designed according to the target respondents: one for the boat-owners; one for the chandlers; one for the professional applicators; and one for the boat yard managers or owners.
The responses will form the basis for a report from the BCF, providing an overall picture of the DIY application of AF paints in the UK, which may then be used as a basis for determining what further support activity is required, for example education tools on hazards and the use of PPE, potential need for advocacy to defend the use of AF paints in the DIY or leisure sector.
Royal Yachting Association (RYA) cruising manager Stuart Carruthers said: ‘Antifouling paint has an important role to play in combatting the spread of invasive non-native species (INNS) and other harmful organisms but, by its very nature, antifouling can also pose a risk to humans and to the environment. The use of biocides like antifouling are therefore closely regulated under EU law.
‘As required by EU law, member states are currently conducting a review of the biocides that are covered by the Biocides Regulation of 2012. We acknowledge that it is important to keep the list of regulated biocides under review but we would be concerned should the review result in any proposal to ban the use of, or weaken, antifouling paint on recreational craft ......
See this link
That's ridiculous! I've seen many professionals doing AF work and they do it in exactly the same way as I do and many others, they roller it on!
i suggest the dangerous bit is rubbing the old stuff down? It needs sanding to key it and get the fresh coat to adhere, you should always use a good quality mask and change the filter a few times whilst working.
