Skylark
My hull is now 7 years old so it's had 7 coats of antifoul.
She was jet-washed by the yard when she came out in November. Around the water line, there's now a fair amount of flaking.
Last year, there was an area of about half a square metre under her belly, forward of the keel that had flaked. I tried to smooth it with a fairly course sandpaper. With hindsight, I wish I hadn't as I probably took as much off the gel coat. The antifoul does seem to have adhered well over this area.
The total flaked surface area is probably no more than 5% but it's starting to look unsightly and no doubt will continue to get worse until I do something about it.
What should I do? Is there an easy way to smooth out the flaking?
Many thanks for your advice / experience.
David
David
