Sailfree
On previous 2 boats I scoured antifoul and applied another coat of Internationals Micron Extra each year. I had these boats for only 3 yrs and had no problems with A/F.
I assumed it was self erroding as certainly near waterline you could see the white GRP grinning through after scouring.
Current boat is now coming up for 7 yrs and last year when I scoured it antifoul came off in patches (mostly on horizontal areas on underside) and also in places as I applied new antifoul with a roller some of these patches extended leaving white gel coat. I sanded these areas down and feathered the edges.
I suspect Bob the Builder who commissioned my boat didn't de-wax the new hull enough or is it the extra thickness of Antifoul that is now forming an independent membrane/layer causing the interface with the GRP to break down?
I would appreciate advice on :-
1. Is this a common problem after 6-7 yrs of recoating hull.
2 Is there a point when you try to scrape it all off and start again.
3. OR do you give it a harder pressure wash and scour it with the green pads and if any patches come off - rub it down locally and feather edges.
Only ever used Micron Extra A/F.
