Burnham Bob
I have to drain and refill my beta 13.5's freshwater cooling system. The drain tap is at the bottom of the engine and with very little room for anything oter than draining the system into the bilges, then pumping it out with the bilge pump. The coolant currently contains anti freeze.
Anyone see any problems? The only alternative i can think of is a pump - the kind you use for changing the oil to put on the drain and then pump it up into a container.
Any suggestions?
Any suggestions?
