purplerobbie
I have a Air-x wind generator and i asked the other day about the best way of charging both house and battery banks.
The answer i got was a split charge diode but a couple of people said there might be a problem with the generator seeing the voltage through the diode.
Would a voltage Sensitive Relay (VSR) work?
If i connected the wind generator to the engine bank would it top off the engine battery then switch over to the house bank?
Or if i fit the VSR would it keep the engine battery toped up when the engine was run and just attach the wind gen to the house bank?
I have to replace all the battery cables as it's a bit of a nightmare in there and i'm not sure the batteries are isolated properly. i can start the engine with the batteries turned off?
I have the alternator a sterling 25 amp battery charger and the Air-x
There is a 330 amp house bank and a 110 engine bank
Rob
Rob
