Another solar panel problem
sailaboutvic
26 Jan 2004
Northern Europe
Friend has two 100w solar panels in parallel one working fine the other wasn't given out any Amps when used my clump on current meter ( which I know works fine ) but the volts was 18v ( tested putting the meter leads over the V+V- open circuit Voltage)
We then decided to test the short circuit current with then panel isolatied as we connect the meter ( set at 10A ) to the lead there was a small spark and all the sudden and the panel spring into life .
Now he finding every morn the same panel doesn't work unless he uses the meter to create the small spark .
Any idea what's going on ?
Panels have been changed around with the same problem happening on the same panel , so it's not the connection .
