ripvan1
What lubricant can be used to ease c/bearing into p bracket?
Why use a press fit when you can slide a bearing in by hand, just bed it on epoxy, removal just involves heating the P bracket.
It doesn't need to be a press fit and there are good reasons why a clearance fit is better.
Mainly 'cos I've bought this one and want to know how to ease it in the p/bracket as per question - thanks for asking![]()
Lady, yes it's the same - old one came out using thread bar and socket and washers device that friend had made up - it's back in his workshop now and he won't be back 'til Tuesday.
I was hoping to get it done over the break along with associated jobs - replace shaft, rudder and prop.
Will try some heat on p/bracket and some vaseline on c/bearing
