Ian_Edwards
Eynhallow has 80m of 10mm galvanized chain +30m of nylon rode, I suspect that it is grade 30, but don't know, it was on the boat when I bought it
The boat is 14m (46ft) and fully loaded is about 16 tons.
The boat is a Southerly, with a lifting keel, which is very narrow, the exact opposite of a long keel boat, as a result she shear quite a lot on anchor in a gale, so snatch loads are probably higher than many boats of a similar length and displacement. Although I do use a relatively long nylon bridal to reduce the snatch load.
I anchor for around 100 nights per year, NW Scotland, generally in mud/clay/sand, I occasionally hear the chain rumble of stone during the night as the wind and/or tide change direction.
The chain is needs to be replaced, or re-galvanizing.
The chain has been end of ended, and is not yet really rusty, but not far off, if I was replacing it I would use it another year.
The chain has been re galvanized once already in February 2017, by Highland Galvanizers, who did a good job, just a couple of links "welded" together by zinc, which cleared the first time it was used.
Current quote to re-galvanize it £500- £600 +VAT, so say around £700.
GS Products are selling Grade 30, 10mm Galvanized short link chain, DIN 766, breaking load 5000kg for £11.11 inc VAT /m, or £888.80 for 80m.
There are other sites selling grade 30 for around that price, eg Force 4 at £10.95
Jimmy Green is selling MF Grade 40 for £14.00 per m, I think inc VAT, or £1,120.
So it's marginally cheaper to get the chain re-galvanized.
I might be tempted to go for 100m of new chain, and remove the 30m of nylon, mainly because the splice between the chain and the nylon doesn't always go through the windlass smoothly. The gypsy is on a vertical shaft, and the rode has to go through a 45 deg bend in the horizontal plane and the 90 deg down into the chain locker. I also thinking that an extra 20m of chain is roughly equivalent to 30m of nylon.
I'm not sure that it's worth going for grade 40?
And I'm tempted to go for re-galvanizing again.
Any comments?
Any comments?
