andyo
Hi – I would appreciate comments on my thoughts on battery and electric arrangements on our newly bought Konsort.
The Konsort is old (1980) but seems well-maintained. It has the original Bukh 20hp engine, a wind generator and solar panel. Last time we went over to Essex for a sail we couldn’t go out as the engine wouldn’t start. It turned over a few times, but eventually I think the batteries had dropped so much that it wouldn’t turn over fast enough to start. I had a close look at the batteries. We have 3 110 Ah leisure batteries, and the common rotary 1, 2, 3 off switch. There is also a battery charger, but I think this is a bog-standard one as you may have for a car.
I’ve read around a fair bit in these pages in the last couple of weeks and think that I should buy a starter battery and use that only to turn the engine. We could also probably do with a modern battery charger. We have shore power in the marina, but I’ve been loath to leave this connected when we are not there – especially with, as I say, an old-fashioned battery charger. I also need to see if the wind generator and solar panel do actually provide any charge to the batteries.
So some questions, starter battery for the engine? New, modern charger? Can/should I leave the shore power connected when not on the yacht, can the charger be left connected to the batteries all the time (previous owner advised removing the croc clip when the charger was not actually switched on.)
I apologise for the length of this post, but I really would appreciate some guidance in this area.
Thanks,
Thanks,
