Anodes ,replace or not
Roy, do they have a white crust on them? You may be more protected from fresh and brackish water in the marina but the river on the ebb has a top layer of fresh to it. I noticed some interesting wear on the anodes. The lower down my drive they were the more rapidly they wore away. Partly due to the SS props I am sure but my anodes on my SS trim tabs seemed to be lasting forever as were my transom shield zincs. They had developed a bit of a white crust from being exposed to the fresh water and were effectively neutralised. I have gone full aluminium now.
Question - doesn't one of the small local streams now divert and empty into the marina via a culvert down the bottom by I leg?
Well if you are on zincs it may be worth your while to go to aluminium. It's not just for brackish water they are reportedly better all round. Just remember you cannot mix and match. All zinc or all aluminium. The was a mission for me. I had to make / shape my own anodes.
Thing is Bruce/Roy
Bruce you are not hooked up to shorepower
Roy is
I have kept boats on swinging moorings in the Srait and pontoon moorings in the river Conwy over the Years
Plus the Strait and Felinheli marina etc etc
Roy, if you say the degradation is only 10% and the Vessel is not due come out and be ashore, leave well alone ,If She is coming out or ashore replace them
Conwy in My experiance is Not a bad place regarding 'Cathodic' Electrolysis' or whatever the corect Term is!
Compared to 'other marinas closer
Not Deganwy but another one Locally
Whlist on a Pontoon in the River Bruce and not 'hooked up' as it were, you have different probs to Roy as you know
If She is ashore Roy just change them
If not from what you say don't bother
What you can do for piece of mind
Plus to stop the 'current' anodes (ooh no pun intended|) degrading too fast as to stop the degradation, is to connect another sacrificial anode to the (green and yeller wires Mate) 'earthing' system and dangle it over the side
Innit!
Thing is Bruce/Roy
Innit!
Kwackers. Tope season is nearly upon us, plus stories of Mako abound. Do you mind if we dangle you over the side? Free beer might be involved :encouragement:
I might tempt Tope
Mako and others of the Shark Family would recognise me as 'bretheren' so they would not Bite
As a tired and semi retired 'used' car sales person
I will dust down my used , formely owned, off of a wagon, fishing rod
Have you got a real reel I can attache?
Anyway we digress. Should Roy change his anodes. I disagree having witnessed first hand what the lack thereof can do. Besides if he doesn't lift his boat out to replace we have a diver in our midst. And if he does lift out we will have the the Easter cruise without having to put up with his sour expression every time I pop over to make sure his funboxes are stocked and working.
All twelve of my anodes were replaced, regardless if they needed it or not. And the boat went back in the water this morning. It’s a false economy not to change them as you don’t know if next season’s conditions will be the same as last.
So anyway, while mooching through the bins and stuff for unwanted valuables, as you do, what should I spy.
In hindsight I should have had a squiz at your anodes but I was so busy searching the bins for a jimmy bar to get into your funbox I clean forgot. Sorry mate
so anyway, while mooching through the bins and stuff for unwanted valuables, as you do, what should i spy.
In hindsight i should have had a squiz at your anodes but i was so busy searching the bins for a jimmy bar to get into your funbox i clean forgot. Sorry mate
did it looked polished
It looked smart. Always has. Difficult to tell when it looks good anyway. Besides, you're asking the wrong person here. Anyway. Has V passed on my message to you, you social media luddite? Will you be back in for the Easter cruise ?
yes
