alanporter
I have a Westerly Renown that originally had a Volvo salt water cooled engine (MC11C). On the outside of the hull there is a plate zinc anode attached by two through bolts. The forward bolt has a wire running to the cooling water intake valve then on to the engine common ground. The after bolt has two wires running aft, and I can't for the life of me see where they are connected, they seem to disappear under the fuel tank. My secondary question is does any Westerlyite know where these wires go ?
My most important question is - I have changed my engine to a fresh water cooled Isuzu ( such a good engine I feel like kissing it every time I go aboard), so, do I need the external plate anode anymore ? My feeling is that it was put on to protect the salt water engine which did not have any internal anode pencils, while the new engine does. I am not an expert in these matters, so I need the wisdom of the forumites. Many thanks in anticipation.
