noname
I have an "IP24" which is a project boat i will be putting back in to the water in march,i have read a few posts regarding the fitting of anodes and would appreciate hearing of your experiences .
My boat has two large steel bilge plates and a keel,also rear lower keel extension and steel rudder.
The boat had about two feet of water in the bilges when purchased last year, and had as a result eaten the aluminium water pump pulley and caused severe damage to the gearbox casings.
Having now fitted a replacement box and repairing or replacing other damaged parts,i am eager to slow or hopefully stop any further damage.
Needless to say the water in the bilges was a big part of the problem before, but with so much metal below i would appreciate useful advice to protect it in future.
Should all engine gearbox components be linked with a cable to electrically connect them together,if anodes are to be fitted should i connect the steel items where possible together.
On my last boat a Sabre 27 the surveyor stated that all Sea cocks and skin fittings should be connected,i have read on here somewhere that only similar metals should be!
confused!! many thanks.
