Anodes again
Lightwave395
14 Aug 2016
Me in Cowes, the boat back in UK now at St Mawes
Apologoies if this is previously covered - I can't find anything at the moment - I keep my boat in fresh water but sail in salt water. Should I have an aluminium or a zinc anode ? Here's a pic of my 15 month zinc anode when the boat was lifted last saturday after 12 months in salt water and 3 months in fresh . I've read the anode page of Mr Cox's excellent website and am leaning towards aluminum at the moment ?
dombuckley
11 Apr 2005
Norfolk
Changing to aluminium seems sensible. In fresh water, zinc quickly develops a chalky oxide which prevents further action, even after returning to salt water.
Tranona
10 Nov 2007
Aluminium. Better in fresh and now becoming the norm in seawater as well. Volvo have changed over to aluminium totally. The potential of the alloy used is virtually the same as zinc, but lighter and cheaper to make 9not necessarily to buy!)
Aja
6 Nov 2001
I have a shaft anode and pear anode, both zinc. I replace the shaft anode every year and the pear anode when required.
Next season, can I put a cheaper aluminium anode on the shaft while retaining the zinc pear anode, or is it not advisable to mix metals (alloys)?
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
Nobody has tested this to my knowledge. Difficult to theorise but the potential of each is very similar, details on my website. Give it a go and let us know: the worst that can happen is one anode will be wasted preferentially.
Aja
6 Nov 2001
My prop won't go fizzle?
Tranona
10 Nov 2007
No. Your comment that you change your pear anode when required suggests it is not doing much. Assuming it is bonded to the shaft to protect the prop this is to be expected because the shaft anode being closer is doing all the work.
Aja
6 Nov 2001
Thanks for the confirmation. I'll give it a try next season and report back in a year or so.
Just don't like being a pioneer, that's all 🙄
