Anode working?
Just use the connectivity setting to test connectivity between the anode and whatever it is protecting. A typical multimeter will emit a beep if there is low resistance connectivity. If there is any paint, fouling, corrosion you need to get through it for the test.
What I do is test the multimeter is getting connectivity first by putting both probes on the anode then both on the keel, for example, then test the connectivity between the two.
