john williams
Active Member
I wonder if anyone can help me with this-opinions would be most appreciated.
I have recently purchased a GRP hulled boat and have noted that there is a fair amount on corrosion on the rudder lower hinge plate. Nothing needs replacing yet but ill have to keep an eye on it.
The top hinge has an anode attached to it on the hull and seems in good shape. The bottom hinge is electrically separate and it looking the worse for it.
I want to attach an anode to the lower hinge and the obvious way to do this would be to withdraw one of the two through bolts and bolt on the anode using the vacant hole. I was going to use an anode bolt to keep the anode electrically connected to the hinge and the hinge bolted on to the rudder but then have begun to wonder if that would be strong enough. The anode bolts I have used in the past seem quite soft and the thread easily stripped.
If I were to drill a new hole in the hinge I'm worried I might weaken it. There dosnt seem a reasonable way to connect the lower hinge to the upper by the way. Any thoughts?
The boat is a 28 ft Morcombe bay prawner.
