oldbilbo
I note these are shown in ASAP Supplies' catalogue and elsewhere as galvanised mild steel with plain nuts - which corrode. Why not stainless bolts with s/s nuts....? Or even galvanised mild steel coach bolts....?
The mild steel is protected by the zinc. Peardrop anodes normally have a mild steel strap cast into the zinc, which is also protected. The mild steel versions corrode when the boat is ashore but not underwater.
Seawater contains loads of oxygen down to considerable depths. The threads of stainless steel might suffer crevice corrosion due to their design, crevices being inevitable in threaded components, but the chances are they will last as long as mild steel ones for four times the price. There is even a possibility that the stainless bolts, being more noble than the strap, will lead to premature failure of the anode strap, i.e. falling off.
Hmmm. I'll just use a couple of the nylon bolts I have in the shed..... They won't corrode when I'm not looking!![]()
Hmmm. I just knew it had to be something 'techie'. I'm unimpressed by all this unwanted corrosion flying about, so think I'll just use a couple of the nylon bolts I have in the shed..... They won't corrode when I'm not looking!![]()
