Anode-Dissolving Antifreeze?
ducked
6 Oct 2024
Came across this while posting on an automotive forum
https://www.commaoil.com/passenger-v...ducts/view/300
The (not very) TDS for this Comma Super Coldmaster stuff (The SDS, often more, though of course still not very, informative, doesn't seem to be there) notes:-
"Avoid galvanised containers for storage or dispensing as they will corrode and contaminate the product."
Oo-er.
This Comma stuff seems to be your "classic" IAT that I understand is usually recommended for marine engines, and probably very similar to the Halfords Silicate stuff I used to flush my raw seawater cooling system before laying up.
I dont have the option of avoiding zinc, since a zinc anode provides essential protection to the engine.
Anode-dissolving antifreeze may not be very important in a raw seawater system, which is essentially an open "total loss" circuit, though it may mean I loose more of the anode while laid up. I'll be checking how much of the anode is left before I run the engine.
Anode-dissolving antifreeze would seem to be potentially quite important where the seawater system has been converted to a closed circuit containing antifreeze, perhaps using a keel cooler.
Is this zinc incompatability a general property of IAT antifreezes?
VicS
13 Jul 2002
Oo-er.
An anode is not required in closed fresh water cooling system filled with an antifreeze solution. If you have converted a direct seawater cooled system you can leave out the anode because the inhibitors in the antifreeze will protect the system from corrosion.
Just plug the hole
ducked
6 Oct 2024
Just plug the hole
My boat still has the original raw seawater system, so definately still requires the anode, which it seems will be attacked by the antifreeze I put in it for overwintering ashore, as is often recommended.
Perhaps an anode wouldn't be required on a converted system, but this came up in the context of someone experiencing galvanic corrosion of their car engine which this antifreeze, (formulated for this type of engine, and not for a converted direct seawater cooled engine) didn't prevent, so I wouldn't bet a lot of money on it.
https://www.honestjohn.co.uk/forum/post/199321/vauxhall-nova-1200-
There's also the possibility of a freshwater circuit losing integrity due to damage or wear and reverting to salt water, in which case it would be nice if the engine survived for a while.
Possibly a magnesium anode would be a partial solution for a converted system, though I dont know for a fact that magnesium is compatible with antifreeze either.
It would probably erode very rapidly in seawater but might buy a bit of time for an integrity loss fault to be detected, perhaps by monitoring conductivity, or, less benignly, by the system clogging with salt.
