TSB240
I have as described a very small leak from the throttle arm spindle.
It looks like there is an o ring on the inside that has failed. I assume I will have to pull the crankshaft pulley off (I have a harmonic balance puller)and remove the cover to gain access.
Has anyone else experienced this problem on the MD 20X0 series?
Any tips or links to a manual would be much appreciated.
I assume it would be sensible to replace any other seals at the same time. I suspect there will be a similar o-ring on the stop lever shaft and of course the crankshaft seal. Are there any others?
Looks like a bad weekend coming up so might as well get it done and I hate any oil in the bilges.
Steve
Steve
