Snowgoose-1
It seems that many yachts have slanting sidedecks . Slanting in the direction to chuck you overboard.
What do think of yours ?
It is to clear the decks of vomit when one of the crew had eight pints of beer and a vindaloo the night before you cast off at 0435 and he did not quite find the bucket.It seems that many yachts have slanting sidedecks . Slanting in the direction to chuck you overboard.
The SO36.2 is appallingly designed in this one small area (excellent elsewhere!). Side decks slant quite a lot outboard, but to add insult to injury there are no real scuppers so it also leads to pooling water and dirt. There are a couple of "scuppers" that are approximately 1mm deep and block at the slightest hint of dust.What do think of yours ?
A properly designed boat shouldn’t collect standing water. The boats I’ve had have had gaps in the toerail for drainage, though they may not have worked perfectly. My current HR has drainage built into the deck. My nemesis is the cockpit drains that have a recess that is always dirty.The SO36.2 is appallingly designed in this one small area (excellent elsewhere!). Side decks slant quite a lot outboard, but to add insult to injury there are no real scuppers so it also leads to pooling water and dirt. There are a couple of "scuppers" that are approximately 1mm deep and block at the slightest hint of dust.
I've never had a boat with an aluminium toerail. Many of them tend to leave grey streaks down the topsides, which I consider a disadvantage. HR never get anything wrong. At least, that's what they want you to think. Much as I love ours, there are a few really silly little things that could have been avoided, some of which were changed in the replacement model. Our design essentially dates from about 1990 and is thus virtually antediluvian.It's an aluminium toerail with plenty of holes, they're just raised a bit from the deck. I'm sure they thought it would be fine during design phase.
HR have the advantage of being 20 years behind the curve on design, so I'm sure take advantage of that hindsight to avoid such issues
Ooh what are those? I've never seen anything wrong on an HR that I can think of, apart from the price!there are a few really silly little things that could have been avoided
I'd never thought about this but the shallow scuppers on mine would do exactly this if I put a drain in so perhaps that's what they were thinking. I could also quite easily install a real drain if I wanted, so perhaps I'm part of the problemwere designed to catch rainwater and fill the water tank
Depends on the angle.It seems that many yachts have slanting sidedecks . Slanting in the direction to chuck you overboard.
You will have to receive this in confidence, since I may want to sell my HR34 one day. As I said, they are minor but daft.Ooh what are those? I've never seen anything wrong on an HR that I can think of, apart from the price!
The inlet seacock for the heads is alongside the engine and only reachable by removing a couple of panels in the aft cabin, as one would in an engine service.
The sprayhood slightly restricts a crew or passenger's headroom if sitting forward.
The aft zip on the sprayhood has to be unzipped when running free or the mainsheet will bear on it
The base of the fridge slopes
The aforementioned dirt-collecting cockpit drain sumps
Having said that, the boat has been ideal for us and has performed far better than we had hoped. And the side-decks don't slope! It's replacement, the 342, which our friends have, has some improvements but is less desirable in other ways.
Bearing in mind the list of serious defects, I’ll offer you £5k for your HR and no survey required. This would enable you to move swiftly on to to the MK2 version you so obviously covet. The £5k is my max budget for a new sailing boat so not negotiable.You will have to receive this in confidence, since I may want to sell my HR34 one day. As I said, they are minor but daft.
I'll think about it.Bearing in mind the list of serious defects, I’ll offer you £5k for your HR and no survey required. This would enable you to move swiftly on to to the MK2 version you so obviously covet. The £5k is my max budget for a new sailing boat so not negotiable.
