Neeves
I have been using Makita angle grinder blades to cut HT steel, Bisplate 80; 7075 high tensile aluminium, stainless steels (which is what the blades are defined or labelled for) and any mild steels. I have had no issues. The blades are v very thin
I was replacing a shower, domestic application, and I had need to cut the copper pipes. There was not enough room for a hacksaw and I simply used an angle grinder - there was some residual water in the pipes - and occasional drip. I thought nothing of it.
The blade shredded cutting the first pipe (standard domestic copper piping)
I queried with Makita - not a complaint - the blades are labelled for stainless no mention of copper pipes. I received the following reply:
quote:
Unfortunately, the bonded abrasive cutting or grinding discs are not designed to be used near any moisture, even though there was minimal water present, any moisture has a detrimental effect on the bonding holding the discs together, hence the reason for the detrimental effect you have experienced.
All bonded abrasive cutting & grinding discs must be stored in such a way that they do not absorb any moisture, as this will start to breakdown the bonding of the discs.
end quote.
I have no complaint of Makita and will continue to use their blades - but I will take segmented blades next time I'm asked to help with a windlass removal. The same blades will come in handy (and be effective) if we ever need to cut the rigging.
It seems that segmented blades are more applicable to be used if water is an issue.
Now everyone may know this, and it may have been aired previously - but I'm renowned for repetition so I thought I'd add a confirmatory post.
Take care, stay safe
Jonathan
end quote.
Jonathan
