Andersen Line Tender - line size?
neil1967
28 Nov 2007
Tavira, Portugal
We have an Andersen Line Tender fitted as part of the roller furling main mechanism. The Andersen instructions state that the Line Tender is only suitable for use with 12mm line; however, when using 12mm braid on braid as a continuous loop, the splice is inevitably slightly thicker than 12mm and it takes an extra tug to get that part of the furling line around the drum of the tender. I wonder if 10mm would be better, but I am concerned it wouldn't have enough grip on the drum to stop a reefed main unfurling at the wrong moment. Anyone tried using 10mm on an Andersen Line Tender?
As a follow-up, I got hold of the selden in mast furling manual (thank you Oyster!) and in there, contrary to the Andersen manual, it’s states to use 10mm line, which I have installed, and it has made furling the main so much easier!
