Djbangi
Hi VYV Cox,
If you were sitting in 5m water with 50m of 8mm chain and the load cell was recording maximum of 120kg then the load on the anchor is almost nothing, in comparison to the holding capacities quoted in the mag articles etc. Assuming max loads come when the chain is at least part lifted off the bottom then the chain weight itself contributes upto 75kg of the 120kg total load. Which surely raises a few queries?
But interesting that you have made the measurements - were these measurements made when you used a snubber? and if you were using a snubber how long is it and where do you put the load cell in the rode, between snubber and chain, between snubber and attachment point on boat etc.
But if you have only loaded your anchor to 120kg in the gusts(what size yacht are we talking about) and that same anchor has a 'magazine article rated' holding capacity of 2t then you are so far from ultimate loading as to be unreal - and the chance that it is set it to max capacity looks non-existant.
Actually I suspect that yacht deck gear is not designed to take 2t loads, but that's only because I think most modern yachts are built to a parsimonious budget.
Have a good night.
Have a good night.
