RobBrown
In process of fitting a manual windlass. As there is a bow well, from earlier advice on here have now got a 3" block of Iroko to raise the windlass on and have a 3mm Al backing plate to help spread the load under the deck (Moody 29 so GRP, not balsa or foam cored).
Queries- what fixative/sealant to use - Sikaflex 291 or something else? Presumably between base of windlass & woodblock & between that & deck? Any between deck & internal backing plate? Is it necessary to glass in the backing plate?
Windlass is also Ally and fitting with A4 SS bolts- have nylon bushes made up for the windlass bolt holes as would have been supplied by S/L from new, but would it be sensible to use Duralac as well?
Have treated Iroko with teak oil and boiled linseed. Is this sufficient weather proofing?
Any other words of wisdom?!
