TradewindSailor
I have always been cautious about fitting swivels in the anchor rode. I don't like them and I think that they constitute a weak point. However I have the following tips:
1 If you fit a stainless steel unit ..... the galvanising on the chain and anchor in its vacinity will gavanically errode. So use a quality galvanised unit instead or be prepared to cut links off the chain periodically.
2 I often see the swivel connected directly to the anchor. In some designs of swivel this is madness as the swivel may have to take a high bending moment if the anchor shank is out of allignment with the pull on the chain .... If a 1 foot length of chain is used between the swivel and the anchor, the chances of high out-of-line loads are minimised.
3 Don't forget to seize the shackles properly and check them regularly.
On another note. I recently picked up a mooring in the Pacific. The lanyard was chain and nylon. The chain looked suspicious so I dived on it. The chain was over 50% corroded and there was daylight around the pin it was so corroded...... the pin was only held in with a single turn of seizing wire /forums/images/graemlins/shocked.gif The mooring owners were not concerned.
