SolentSnowgoose
Hi All
I know that there is a huge debate about "what is the best anchor" but I plan to update my anchor and chain prior to more extended periods of cruising and time at anchor and would appreciate some advice.
We sail a 37ft Snowgoose Cat and currently carry
Main anchor : 20Kg CQR + 10m x 10mm Chain + 50m x 18mm Octoplat ( we often lay with 5x depth of rope and hence have a large swinging circle)
Secondary : 45lb Fishermans + 25m x 8mm Chain + 40m x 16mm Octoplat ( acquired as a "Rock Anchor" for Scillies but rarely used )
Kedge : Fortress FX 11 + 10m x 6mm Chain + 40m x 16mm Octoplat ( Bought for smaller boat but AMAZING holding in mud/ sand)
I plan to replace the secondary with : Fortress FX 37 + 10m x 10mm Chain + 50m x 18mm Octoplat
For the main I plan either a new generation SHHP anchor ( Spade/ Rocna / Manson ) with extra 10mm chain & warp
However I don't want to add too much extra weight ( bad at the bow of a cat) so the trade off is either :
a) 20Kg SHHP Anchor with 25m x 10mm chain or
b) 16Kg SHHP Anchor with 30m x 10mm chain
Question ...
Given the advantage of SHHP anchors over the CQR is it reasonable to go down a size in order to have a bit more chain so that we can lay to all chain and reduce the swinging circle
Or is it better to put the weight into the anchor and lay to a bit more rope ... This is the way I am tending at the moment on the basis that the ultimate holding power depends on the Anchor once the chain is bar tight and the rope will then be more effective in dealing with snatch loads
Dare I ask on comments on the 3 potential SHHP anchors ... I like the Spade but its very expensive, I like the Rocna but am just a bit irritated by some of the comments by those promoting it and hence am now tempted by the Manson based on price / value.
All experience, comments and advice appreciated
Question ...
