mtb
You're compltely ignoring the effect of drag from the loose chain if the anchor fails to set. Just try dragging 20 metres of 10 mm chain across the boatyard some time and then apply the knowledge you've gained to a sea bed.
Having heavier rig is fine if you're hale and hearty enough to haul it up if it snags or you have windless problems. For older and less athletic members more creative solutions are required. The additional chain just acts as a multiplier. Try it.
the loose chain will not dictate how the anchor lays, their designed to have the load pulling at a certain point. With loose chain your likely to not allow the anchor to set as it should, the anchor could be sat on its side and not able to set as it should
