Duffer
I usually use a masthead mooring light or a solar light in the rigging when anchored. What does the panel think about using both at the same time when anchored near a fairway (and therefore you want to be as visible as possible)?
In some circumstances a masthead light can disappear in fog and in others the solar light can run out of juice. Would it be confusing/misleading/impermissible to use both or do you think in some situations you should make yourself as visible as possible?
