apindrans
New Member
I own a wooden Vertue sloop (25ft, and 5tons), and the current anchor arrangement is one 35lb CQR, 50m of chain, 100m of warp, and a hand operated windlass, and a 20lb danforth kedge.
So far I have not had to anchor the boat as all I have been doing is out of the marina and back again. However, I'm daunted by the prospect of chucking all the anchor gear over the bow and not being able to get it back on board again!
I'm mulling over the different anchoring options I have available.
1. Keep the same gear and install an electric windlass. (Expensive, what happens if the windlass fails?, overkill for a small boat, not sure on the integrity of the current chain)
2. Keep the same anchor, but reduce the length of new chain to 10m (problem of getting anchor abooard, getting the warp to flake through the chain pipe)
3. Get a smaller, more efficient anchor (Fortress or Spade) with chain and warp combination, and use an anchor chum (still problem of getting warp through chain pipe, will this combination be sufficient security for a real blow?)
Your opinions and ideas would be most welcome.
