greggron
Has anyone got any recommendations for this? I have a Garmin 152 on board but it's not intuitive for me to set and the alarm is pitifully quiet. I'm looking to supplement it with a back up in the iPhone.
We use My Anchor Watch Pro. It's absolutely fantastic. You can configure it to only check every 30 seconds. Because GPS accuracy is initially low on warm up, if it finds an alarm condition it then operates as per your filter settings for false alarms. I set ours to do rapid re-tests 5 times over a few seconds. Result is nearly zero false alarms and low battery drain. My phone lasts easily all night not plugged in.
I reviewed it when we first got it:
http://www.yacht-forum.co.uk/viewtopic.php?t=687
+1I'm using Drag Queen.
Very easy to use.
As Sophie already stated only if connected to a charger.
I recall reading an article that warned people to avoid using phones with GPS for this type of thing. Something to with with using phone towers and if no change in 10 minutes it turned off for short periods.
You can be in lot of trouble in well under 10 minutes.
Good luck and fair winds.![]()
