AHoy2
Re: An answer to the \'what oil for my engine\' question
Take a look at Fuchs/Silkolene who supply to the commercial sector with a large range of products. This includes diesel engine multigrade and monograde. Their website(s) take some getting around to find product specs so for starters look here:
http://www.fuchstz.com/pagediesel.html
This lists multigrade and monograde oils that should meet some of the availability concerns expressed earlier.
On the recommendation of their UK tech centre I am using their TITAN UNIVERSAL HD 1540 which is API CG-4 (but also carries a CD classification listed on the container but not on the spec sheet). Engine is 3 litre 200hp TD with 200hr drain intervals.
If you are Poole based then Upton Oils (off A350/A35 junction) are the local suppliers, 20 litres for around £38 if I recall. "Bulk" supply only, not by the litre can though! No connection other than as a customer.
I believe Fuchs supply to VW, MAN and MB for engine factory fill and from my investigation also seem to have a good commercial reputation. UK support and supply as well.
A.
A.
