Some time ago this was taken of my boat when engine was changed .. as the delrin bearing ring had worn out (previous owners lack of checks). The result was the rotary blade part had gouged a slight ... maybe 0.1mm ridge into the standing blade part. I never bothered to fix it or refit.
Now the boat is here at my house and I rescued the bits from the depths of the locker ... they all still fitted, bolts still in good nick etc. I found if I turned the boss round that keeps the standing part in line - the cutter works but gap is close ... if I put it back the way it should be ... the gap is large and standing part flops around ..
So the question is ...
1. can the standing part be ground flat again .. difference would be tiny to original ... and new bearing fitted ?
2. can a new bearing be fitted and ignore the slight ridge ?
3. can the boss be turned around and used without new bearing - as long as rings have small gap ?
4. last option is 'orrible as cost of new one is *£$%^&*
I am sure if I spoke to AM - they would offer me new one ... at a price !!
Anyone else had same ?? I'm undecided what to do with it ... as I think it would be a good idea to have it back on - the river at my house has "illegal" nets in some areas ... a stripper chomping them to bits seems fitting !!!!
